Grid Theme | Images have wonky width issue
1395
07-22-2022 09:26 AM
MichelleWilliamsERM
I want the image to have a width of 2, BUT it doesn't hold the width.MichelleWilliamsERM_0-1658506708911.png
The work around is to have the overall at w8, the next line at w6, add the photo, and then add the next option at 2w (so it's forced to go to the next column, because it adds up more than 8).
Is anyone else having issues with other types not holding it's width?
Survey123 Jedi ~ and still learning
DougBrowning
MVP Esteemed Contributor
Have you played with the newer dynamic vs fixed grid types?  All my forms are old style of just grid pages and they can get funky now with the new style.
See https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-groups-grids-and/b...
and https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformsappearance.htm
By setting the style column on the settings sheet to fixed-grid or dynamic-grid, groups in your survey can be set to display the contained questions in a grid.
The fixed grid style creates a placeholder for each question, including those with a hidden appearance. A question will appear if its relevant conditions are met; otherwise, a blank space will occupy that place in the form.
The dynamic grid style allows questions and groups to move on the form, depending on relevant conditions to make best use of the space on the device screen.
The grid layout style on the settings worksheet is a global setting that applies to the whole survey. You can also apply a grid layout style for individual groups or repeats, allowing different styles to be used for different parts of your survey. The global setting can be overridden by entering either of the following in the body::esri:style column of the group or repeat question:
layout=dynamic-grid
layout=fixed-grid
MichelleWilliamsERM
Yes, I tried all the layouts, and the photo is the object that doesn't work, so I thing it's an issue with that item.
I have a video if Esri wants to look at it.
 @DougBrowning are you from Esri?
DougBrowning
No all esri staff have a little green banner on them that says esri.  It looks like you have a repeat in there?  That may do it.  Not sure.  Maybe post the whole form and a grid god may know.
MichaelWallace3
I am having a similar issue. Can I just substitute a newer forms excel template for the older one? I want to take advantage of the new styles like fixed grid.
