Getting a code when I submit data on Survey123 mobile app
599
10-06-2025 01:18 AM
NkatekoMarima2
When submitting forms on Survey123 Mobile App I get the message:
"Please copy this code, switch to your application and paste it there"
I tried to sign out and sign in, but it brings the same message again when I try to sign in. I have never encountered this error, please assist.
Thanks
Nkateko
CodyPatterson
MVP Regular Contributor
Hey @NkatekoMarima2
Is this using an ArcGIS Online connector or an ArcGIS Enterprise connector? The reason I ask is because there is this article from a similar issue, but this is with PowerPoint: https://support.esri.com/en-us/knowledge-base/prompt-to-copy-and-paste-code-into-an-application-when...
There is also this article from 2017 with possibly helpful information: https://community.esri.com/t5/arcgis-survey123-questions/sign-in-to-arcgis-online-with-survey123-oau...
Could you attach a screenshot of the error? Feel free to blot the key out if you would like!
Cody
CodyPatterson
Hey @NkatekoMarima2
Cody
NkatekoMarima2
Good day
It is using ArcGIS online. I tried resetting the password and the form went through. Thank you so much.
Nkateko
