Geotrace map different when changing language
757
05-17-2023 06:34 AM
ScottStepro1
I am using the enabled inbox survey built on a feature class and is working like a champ as expected. Currently when the user selects an entry from the inbox, the map zooms to and highlights the selected asset...  however...  the issue I am having is that when the user chooses a language besides the default, the map changes from a map showing the selected asset to the view set in the map tab of Survey123 connect.   If I switch back to the default language, the map continues to show map tab view.  I have not found an reference to that as of yet and hoping someone can help...
Otherwise, language additions work as expected.
Heres to hoping this make sense...
Tags (3)
