Geotrace in the Field
460
05-20-2025 09:48 AM
TraceyGeneau
I am trying to figure out a way to trace my steps automatically when I am in the field.  What I would like to do is walk the border of a wetland and have it record where I go.  I thought of Geotrace but it doesn't seem to automatically follow me.  I also read this can be done in Field Maps but I am still trying to figure that out too.
This is what I have.
typenamelabelhintguidance_hintappearancerequiredrequired_messagereadonlydefaultcalculationconstraintconstraint_messagerelevantchoice_filterrepeat_countmedia::audiomedia::imagebind::typebind::esri:fieldTypebind::esri:fieldLengthbind::esri:fieldAliasbody::esri:style
select_one sitesiteSite
dateTimedateDate
select_multiple surveyorsurveyorSurveyors
textPolygonPolygon(s)
geotracewalk_traceWalk Boundary/Path                   method=vertex
textwalk_idWalk ID (optional)
begin repeatobservationsObservations Along Path
imageobs_photoPhoto
geopointobs_locationLocation of Observation  hidden    position()
textobs_notesSpecies/Observation Note
calculateobs_timeTime of Observation       now()
end repeat
TylerGraham2
TraceyGeneau
Haha.. I figured it out with your help.  We both were kind of off.  We need method=vertex streaming.  Both need to be there and then it changed.  Thank you.
MobiusSnake
MVP Regular Contributor
You might want to look into QuickCapture for this, I've used it for similar workflows and it's worked really well.  (Although I've created linear features rather than polygons... not sure how well it would work for polygons.)
One handy feature is that you can be capturing multiple lines at once provided they're part of the same project, so for example you could be capturing the boundary line while simultaneously capturing a fenceline.
TraceyGeneau
I wanted to say thank you.  I got it working.  🙂
