Geopoint within a repeat causes sticky select_one / select_multiple
426
06-21-2018 12:51 AM
ShanonLoughton
Hi, Geopoints within a repeat cause further/later items within the repeat, such as select_one and select_multiple types to not clear when adding a new repeat. It is probably related to Geopoint types themselves not clearing between repeats, which is probably a known bug?
Versions:
Survey123 Connect 2.6.4 - 2.8
Survey123 for ArcGIS 2.6.7 - 2.8
OS: Windows 10 64bit
See attached survey example.
ArcGIS Enterprise Admin Professional, AWS Solutions Architect Professional
JamesTedrick
Esri Esteemed Contributor
Hi Shanon,
We believe we have resolved this issue in 3.0.  Can you try a beta version of the release via the Early Adopter Community?
