Formula
4737
12
07-18-2022 10:53 AM
DrJumaKhudonazarov
I need to put a formula on survey 123 to calculate BMI (Body Mass Index). Can someone help me please with how to do that?
DrJumaKhudonazarov
Sorry for not being clear. I have  3 measurements
1. <80 cm :
2.  81-102 cm
3.> 103 cm.
And there 3 risk  groups@
1. Low
2. Medium
3. High
What i want is that if i select   >103 cm   the answer  in next question  should automatically  appear  as  red colour text  High risk,  this may not affect analysis  but the person who measure WC can explain  the risk for that  person .
Katie_Clark
MVP Regular Contributor
Ah ok. In this case, I would set up individual "note" type questions that will display conditionally based on the answer selected in the measurement question. You can use HTML formatting in the "Label" column of the XLS form. See example below:
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
DrJumaKhudonazarov
As always  thank you so much  it works !
