Format Sent Information
752
02-05-2024 09:45 AM
kapalczynski
I have a form that has SENT enabled so the user can view and copy to new record.
My question is .. Can I format the text as seen in S123 Form .... see below...
Can I specify that fields I see here etc.
DougBrowning
MVP Esteemed Contributor
You can set this in the instance_name column on the Settings tab in Connect.
