Filling out Surveys using a Panasonic ToughPad running Windows 8.1
2616
03-16-2016 08:39 AM
Chris_Anderson
I would like to use a Panasonic ToughPad, running Windows 8.1. I can create surveys using Survey123Connect, but can I collect data using one of these surveys? Survey123 for ArcGIS is not available for this device.
Tags (1)
HannahFerrier
Go here: Survey123 for ArcGIS - the scroll right down to the bottom of the page and download the Survey123 App for Windows.
It works the same as the mobile apps - sign in, download your surveys and start collecting data!
Hannah
DougBrowning
MVP Esteemed Contributor
I use Survey123 on Win7 not sure about 8.  Download the Survey123 for Windows (NOT the Connect).  Player vs Builder.
HannahFerrier
Hannah
Chris_Anderson
Thanks for the info. I was able to get it to work.
