Field Record will disappear when using repeat in inbox
327
02-17-2025 07:50 PM
IDT_tinghuahuang
Using Survey123 version 3.21.66
I design a survey using repeat and in box.
The problem field is a "select one" question with a choice_filter.
The choice looks like
resultname1label1Y
resultname2label2Y
resultname3label3Y
resultname4label4Y
resultname5label5Y
resultname6label1N
resultname7label2N
resultname8label3N
resultname9label4N
This works fine when collect data.
However, when open the record from inbox, the data in field always disappear.
I check the database in smartphone, and the record is fine.
So it's must be the APP.
IDT_tinghuahuang
UPDATE:
I use body:visible instead of relavant and it's fine now.
IDT_tinghuahuang
UPDATE:
I change the design of my survey.
I use two different "select one" question instead, and using relavant (N or Y) to display different situation.
When it's N, everything is fine. When it's Y, the question have correct choice, but data always disappear when open from inbox.
IDT_tinghuahuang
UPDATE:
