Feature Reports for multiple features
1510
05-05-2025 06:36 AM
JamesTurner2
I have a survey123 form set up with repeats to complete inspections. The records are all associated with a group, each group may have multiple records per year in submitted to the survey. So there might be 3 inspections for Group A that all have 5 individual POIs. I want to create one report which shows all of the POIs that failed inspection over the course of a year for Group A. This is similar to a summary report, but I need to be able to show the individual POI data in the report. Essentially I am looking for a report that says Group A has 7 POIs that failed inspection this year and here's which ones. I don't need to include any data from the parent records.
We currently have a feature report that is generated when a new record is submitted, I would like to keep that format. My initial thought was to use python to find all the failed POIs for each group and create a bogus record in the feature class to hold those (as if it was an inspection with a bunch of failed points). From here, I could just generate the report using the existing template. This actually works, but my POIs have attachments and I can't figure out how to add those to the 'new' POIs so I can see them in the final report.
Is there a better approach here? Or a method to add attachments to a feature via python?
Neal_t_k
MVP Regular Contributor
If I am understanding your scenario correctly, this can be done using the report feature.  You will have to start and end tag your repeat section, and then use the conditional function to get just the POIs that failed.
https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereport-repeats.htm
https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereport-conditionalelements.htm
JamesTurner2
I believe that is what we do on the feature report for each inspection (1 parent record). I don't think that enables us to pull POIs across multiple parent records into one report? We need to pull features from multiple parent records but still include the details of the individual features.
Neal_t_k
Yeah, sorry, I somehow missed that even though I went back and re-read this morning and its right there.
TylerGraham2
Here's some guidance on summaries. Take a close look at the Include select values section for including individual responses along with the summary.
Report queries—ArcGIS Survey123 | Documentation
