Feature report pulling erroneous GPS coordinates
1067
09-01-2023 10:26 AM
alyssajhnsn
I'm not sure why, but my feature report is pulling completely wrong GPS coordinates. They go nowhere and they are not the GPS coordinates listed as associated with the survey record. Any clue what's going on or how to fix it?
IsmaelChivite
Esri Notable Contributor
@alyssajhnsn  I am sorry but you will need to be way more specific for people to be able to help you. I suggest you try to reproduce the problem using a simple survey and report and then share the steps that need to be followed to reproduce the problem. By doing so, you may find a solution yourself. Worst case scenario, someone here may be able to help you once you provide more details.
