Hi!
I am working on preparing a feature report for a Survey123 Connect form which is functioning. I can see the light at the end of the tunnel and am curious if there is a way to...
1) duplicate headers from tables to preceding pages? I have Repeat Header Rows on Word selected.
and 2) configure the format of stats:"sum,xyz" to display the hundred separators? Right now, stats:sum is summing my total up in the 12345 format instead of 12,345.
I have attached an example of the feature report. Thanks in advance!
Brooke
Hey there!
Unfortunately I'm not sure how to answer your first question, but I do have an answer for your second.
Try adding either the method useGrouping or format in your sum statement.
E.g.,
${Leachate_Report_Final | stats:“sum,Meter_Total” | useGrouping:true}
or
${Leachate_Report_Final | stats:“sum,Meter_Total” | format:"#,##0"}
Note this should group numbers with a grouping size of three which would work for numbers in the ten (12345 --> 12,345) and hundred thousands (123456 --> 123,456), but I don't believe it will for numbers in the thousands (1234 --> 123,4). Try the useGrouping method first and see if it works for you!
For reference:
Note that the reference page custom to your survey can be found on the Survey123 item page for your survey > Data > Report > Manage Templates > Quick Reference
Hope that helps!
