Feature Report for Photographs
688
03-11-2020 02:32 PM
deleted-user-PUOLzzPmi8Uz
My inspection survey can have up to 25 photos collected per asset. A photo is captured only if a defect is found.
Is there a way to create a Feature Report document that would limit to only those questions with a photo? My current Feature Report does this to an extent, but it leaves a blank cell in the table when the if/then test proves false (e.g. ${if (Photo5 | getValue:”size”)>0} ) for each question. For instance, I could have only four photos for the asset, but three pages of blank cells until the if/then for a Photo proves true. My objective is to get rid of the blank cells, so that if a report has only 10 photos then all 10 get placed in a grid like pattern over the pages without any blank cells in between. Hope this makes sense. Any guidance is much appreciated. Thanks!
JamesTedrick
Esri Esteemed Contributor
Hi Jason,
Apologies for the delay.  It would be helpful if you could provide a sample of what is currently generated and what you would like to see ideally.  That being said, this sounds like perhaps an issue of exactly where and how the ${if} clauses are applied- one thing that I've seen is the author place a carriage returns that aren't covered by the 'if' clause, causing them to be included unintentionally.
