Extracting Survey123 data from Device
11031
12
07-24-2017 09:34 AM
by Anonymous User
Not applicable
Some staff have been collecting data using an old version of a survey that points to a feature service that no longer exists. The data is stored in their sent/outbox folders. Is there anyway of extracting that data without having to manually write it down?
SethPaine1
Your ObjectId field is all in caps.  Two lines above the line that threw the error (line 89), try changing "objectid" to "OBJECTID"
SolanaFoo2
Hi Seth,
I'm getting this error, any ideas?
** <out_info_file> Record length 4168 exceed max record length of 4096 bytes **
ERROR 999999: Error executing function.
Failed to execute (AddField).
Thanks for the script though!  Got me farther than before!
FYI I've got field names longer than 16 characters so I'm already taking care of that by [0:16].  This got me past the first error of invalid field names.
DougBrowning
MVP Esteemed Contributor
Bump to Please consider opening up the file system in iOS so that we can backup while offline.
Please - we really, really need it.  Works in Collector.  Thanks
https://community.esri.com/thread/247270-backups-while-offline-on-ios
