external choice image
1212
03-16-2023 10:13 AM
stormec
I am continuing to develop my survey. It would be nice to incorporate as images or (pdf files) associated with a selection made.
A linked csv file provides information associated with available choices via pulldata function.
I would like to know options and examples of how to accomplish this, if possible.
I tried moving a file to AGOL and coping url into csv. Did not work.
Thanks, in advance.
DougBrowning
MVP Esteemed Contributor
You can do it.  Just add a image column to the csv then the name of the image that it is in the media folder.
I think this is what you mean.
stormec
Thanks @DougBrowning
What should the question type be?
With your example above, what would the code look like?
DougBrowning
Just a standard select one.  The images will be next to the choice and you can tap them to make them bigger.  No special code it just uses the image column if it has it.
Works on select multiple also
Just try it, it is easy.
