Extending Survey123 smart forms JS functions image parameter
1014
11-26-2021 06:30 AM
SébastienFancelli
hello,
I want to use the javascript extension to send an image to an external API for analysis. when I try to send the image as a parameter with the pulldata (ex: pulldata ("@ javascript", "myFunctions.js" ", $ {image}), I get the name of the image on the javascript side.
Do you have a solution for me to transmit the complete image (encoded 32 or 64) on the javascript side?
Thank you
IsmaelChivite
Esri Notable Contributor
Hi. It is not possible to pass the encoded image into a custom JS function. Additionally, it will be very difficult for you to control when exactly your JS function executes, causing multiple uploads of your image to your service.
As alternatives:
  • You could create a custom add-in for the field app.
  • You could use workflow automation (Integromat or Power Automate) to process the image once the survey is sent
