Exporting data from Survey123 with names instead of labels
3724
6
04-07-2021 06:24 AM
SwathiIyengar
Hi all,
We need to export data from Survey123/ArcGIS Online using field names instead of labels. I know this question has been asked a few times in the past (in 2017, in 2019, and earlier this year).
One of the solutions suggested, "changing DisplayName in the AGOL Feature Layer to be the value you want to see in Excel, the next Excel export will pickup the change." How does one do this?
Another solution suggested populating the column bind::esri:fieldAlias - to confirm, that would look something like this (assuming we want the name fields to appear in the excel/csv exports)?
typenamelabel::English (en)bind::esri:fieldAliaslabel::Persian (per)
begin grouphouseholdinfoA. PRELIMINARY INFORMATION / ADMINISTRATIVE SURVEY DATAhouseholdinfoA.اطلاعات اولیه / داده های اداری نیازسنجی
Thanks!
IsmaelChivite
Esri Notable Contributor
Hi @SwathiIyengar   No news on this one. For clarity, Survey123 is limited to what the export capabilities of ArcGIS Online and ArcGIS Enterprise provide.  The solutions provided in the links you include are still valid.
SwathiIyengar
Hi @IsmaelChivite ,
Thanks - with regard to one of the solutions, can you provide some additional instructions (see below)
Thanks!
RichardRogers1
Are there any plans to resolve this?  An option to choose actual column headers ("name") rather than field aliases ("label") would save much trouble on the next step in the data workflow (in my case, pushing data into a separate database).
MicZatorsky_AEC
Find the feature layer that your survey uses  > Data tab > Fields tab
Select a field, change the name.  For example:
SwathiIyengar
@MicZatorsky_AEC - thanks a million!
ConsueloMartinez
It doesn't work TT
