Export Table With Domain Labels Not Coded Value
736
12-30-2025 10:59 AM
BigLouC
I have searched int the community for a solution, but found none.
I need to export the table with the domain label, not the coded value in the choice tab of the form.
Every time we export, we get the code, which is useless when reading the table as an end user.
Is there a step I am missing to make this happen?
Thanks
Neal_t_k
MVP Regular Contributor
You can make the name and label the same... or you could also capture the label in a separate question.
see ":jr:choice-name(choice, 'question')" section:
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-xlsform-functions/...
DougBrowning
MVP Esteemed Contributor
I have had the best luck with using the Export to Excel tool in ArcPro which has an option for this.
I think a web map can do it also.  Probably a dashboard also.
Also ArcGIS for Excel addin can do it - bonus no need to export it just connects live time.
