Export Nested Survey123 Images to SharePoint using MS Flow
1143
07-28-2023 12:29 AM
JaymieCroucher
I've seen lots of guidance around setting up a flow for sending images from a survey via email and to also uploading images to SharePoint (see below).
https://support.esri.com/en-us/knowledge-base/how-to-include-arcgis-survey123-photo-attachments-in-a...
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-working-with/ba-p/...
Having followed both I've now successfully got a flow which lists all photo urls and has the ability to upload individual images to SharePoint (attached).
I now however have a problem around sending requests for multiple photos which are nested within a single question.
If I send individual requests (i.e. for surveys with only 1 Image) the flow runs successfully however if the nested survey question has 2 images associated I get a forbidden error as its sending 2 requests using the same token which individually work fine.
Are there any workarounds on delaying apply to each iterations or am I missing something with the token authorisation?
Any help or guidance much appreciated as this has been keeping me awake at night!
