Existing Data Service not Compatible with Survey
564
01-27-2020 01:05 PM
branden_villalonaVillalona
I updated a survey in Survey123 Connect, which altered the schema of a repeat.  I went into the table in ArcGIS Online and made the changes to the fields, but it will still not let me publish.
The error is this: The existing data service is not compatible with the survey - (Fields not found in the feature service: 2).
Am I overlooking some detail as to how I can add the fields and have them publish?
LynseyBlackburn
As a best practice, it is not recommended to make schema changes to a survey or associated feature service once published. This can lead to data corruption or an unusable survey. I would try to create a new survey from that existing, updated feature service and compare the newly created form with the original one that you are editing to see if there are any differences/ fields you are missing.
-Lynsey
