Error when trying to create/import report template for a survey
13473
24
10-16-2020 01:26 AM
Mondi_GIS
Hi all
Since late yesterday I have come across something weird when wanting to create or upload a report template to a survey in ArcGIS Online. I get the error you see below. The survey works perfectly in every other way, but it is only the report that is causing an issue
It says "Item specified by surveyItemId does not exist or is not accessible.
What is this surveyItemId that is spoken about? How can it not exist?
I get the same error when I try upload new templates to several existing surveys that are currently using reports that have been uploaded before. Weirdly enough, if I publish a simple survey it all works well.
Has anyone had this issue before. I first thought it was a issue with my one survey that I was currently developing, but it is now doing it with several of the existing ones.
Is there some update to ArcGIS online that I don't know about?
Thanks so much
Paul
Mondi_GIS
Thank you
I have logged a support ticket with our local ESRI support. Ticket Number "Esri Case #02661221".
I would appreciate it if you could keep me informed on timelines, as I am not able to produce any reports for these surveys at the moment.
Paul
HaroldHerrera1
Hello Ruth, it is possible to share the XLSForm, can you share your Email?
On the other hand, this problem has been present for a few days, I have not been able to update the forms already developed because the reports would stop working.
The form that presents this error contains "external choice" however until a few days ago it worked without any problem. It seems to me that when the update was done, for some reason it changed in SurveyItemID.
We reported this issue to support "Esri Case #02660816"
I will appreciate informing when this error could be fixed, It's very important to produce the reports in the queue.
Mondi_GIS
It seems like ESRI did something related to external choices and now surveys that were published with them have issues.
Hopefully it gets sorted out soon
ZhifangWang
Hi Harold Herrera‌,
Can you please send the XLSForm to "[email protected]"? This will help us to confirm the fix. Thanks.
HaroldHerrera1
Hi Zhifang Wang,
Email send!
ChristinaKimbrough
Hi Paul & Co, can I ask if the surveys that are giving you trouble have repeats in them? We're having connection issues with Microsoft Automate but only for a particular survey (contains repeats). Thanks, Christina
Mondi_GIS
Hi Christina
My surveys that aren't working do have some repeats in them, but it is only the ones that have external selects in them that aren't working. My others that don't have external selects, but which have repeats, seem to work fine.
One way to test it on your side is to just publish a dummy survey with repeats in it and see if you can get the reporting working on it.
I hope this helps
SrinivasaRao1
If we need to create a custom template with some other questions added, is there any possibility of changing template and importing into survey123, if so please let us know as one of client want to include some items which are not there in the template?
Regards,
Srini
Ruth_JiatengXu
Hi Srini,
Yes, you can import your custom report template into Survey123 using the new template button. The provided sample template can be used as the base of your custom template, and you can also use the new Quick reference page as a syntax reference of the report.
The report is a pretty powerful tool, and here is a blog introducing the report functionality which is worth reading https://community.esri.com/groups/survey123/blog/2019/07/23/understanding-survey123-feature-reports.
Ruth
Ruth_JiatengXu
Hi all,
Admin AdminHarold HerreraChristina Kimbrough
Thanks for the help, the fix is now available for testing on our BETA website https://survey123beta.arcgis.com/, if the hotfix build passes the test, we will then deploy the fix on the production website next week.
Ruth
