Error:undefined
2523
05-16-2022 04:48 PM
by Anonymous User
Not applicable
Trying to upload a template for the first time. I've fixed several of these error messages within the repeats, but this one I'm not sure how to fix.
Failed to parse ${leave_trees} since leave_trees cannot be found in the current parsing scope.
Tags (3)
ZacharySutherby
Hello @Anonymous User,
Would you be able to pass along the XLSform for your survey for reference? A few things to check:
- Is the Existing Site Assets section in a repeat? If so that section will need the repeat tag around it.
- Is leave_trees the exact name of the question in the survey?
- If you create a sample template what is set for that question in the template?
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
by Anonymous User
Not applicable
Zachary, thanks! It was the repeat that was holding it up. I had to add the syntax to end the repeat.
