Error in Survey123 Web Application "Collaborate: Who can view results of this survey?" settings
1555
04-20-2023 02:28 PM
jhansen_GEI
Hello everyone,
I have a survey that I published using connect and would like to change the settings to allow users from a group to view the results of the survey. I have done this often in the past but received this error message today:
Does anyone have an idea on how to resolve this error?
ChristopherCounsell
MVP Frequent Contributor
In ArcGIS Online, have you changed the Survey123 folder or items within for this survey? 500 errors with unknown is a generic server error message. It seems like it can't find or modify the view layer required for collaboration.
Personally I prefer manually creating my View layers for stakeholder access. You can do so via the Hosted Feature Layer page and then share as required via maps/apps.
BenHamada
Did you happen to figure out how to resolve this?  I am having the same issue
jhansen_GEI
@BenHamada Try updating your settings on the feature layer and form to as unrestricted as possible. I ended up changing my settings around a bit and got it to work and then tailored the settings to the restricted use level I needed.
