Passing Values From Survey123 to Field Maps?
1579
09-19-2023 05:11 AM
DaveK
I have a workflow which involves a Survey123 form as well as a field maps application. Is it possible to create a link somewhere in the Survey123 form that will open up Field Maps and auto populate specified fields with information from the survey? If so, how can this be done? Any help is appreciated.
Thanks!
clt_cabq
This is definitely doable - here's a good post that includes a few links that are helpful, especially follow the information from Doug Browning's response. When I've done this before you end up with a process that creates a link in the field maps feature you collect that opens the Survey 123 form. But read through the various links and tips offered.
Integrating Survey123 with existing feature layers
