Error Generating Survey 123 Reports : Error Reads "The task failed because all reports failed to run printIndividual"
8305
13
06-24-2022 01:06 AM
SindiswaMsubo
Hi ! I need assistance please.
I have been using Survey 123 Website to generate feature reports without a problem, for the past couple of months. However recently whenever I try generate a report it gives me the error : "The task failed because all reports failed to run printIndividual"
I have removed the initial report template I created and tried using the default template provided to generate the reports again, however I still get the same issue. I need to be able to generate these reports ASAP. The Reports need to be submitted by the end of next week.
Any Ideas on how I can solve this issue?
WalterWilliams
I'm having the same issue is there a fix that can be shared? I have attached a screenshot of the error message
RENDANIMUDAU
Good day,
would you please share the solution to the problem if you managed to solve it?
ilee_sjc
I am having the same issue...when creating reports with more than 20 records. The only fix is if I create 10 reports a time.
OliviaHarrison
I've just run into this problem too, using a template that was working with no issues. I've tried the workaround that I found here but it didn't work.
Anyone found anything that works?
