Error generating reports after Survey123 update
11365
29
02-28-2019 06:45 AM
RobBlash
See attached screen shot. I have several users who cannot generate reports (different surveys, but all are set up the same). These are existing surveys with existing templates that worked before today. The RemarksText field exists in the survey within a repeat.
Could this be related to the 3.3 update?
Update: I was told by Esri support that there is nothing they can do to help me since reports are in Beta. I have many reports that were working previously but now fail after the 3.3 update. James Tedrick‌ and Philip Wilson‌ do you have any ideas on what may be causing this? The field that's failing is in a repeat.
by Anonymous User
Not applicable
Hi Rob,
At this stage, we are aiming for the fix for this issue to be available and applied to the website by the end of next week. If you can wait without needing to make changes now, that may save some time and effort.
Phil.
RobBlash
Thanks for the into Philip. Is there any timeline on when reports will move out of Beta?
Rob
by Anonymous User
Not applicable
Hi Rob,
Currently there is no fixed date to move the Report feature out of beta and into final release, however we are actively working on it and aiming for later this year, it could be as soon as the UC release, otherwise shortly after.
Phil.
RobBlash
Thanks for the info
HaroldHerrera1
HelloJames Tedrick‌ and Philip Wilson
Do you have a date line to solve this problem?
JamesTedrick
Esri Esteemed Contributor
Hi Harold,
We had a few issues identified in testing that delayed the release of the hot fix.  We now expect to release it later this week, assuming no further issues arise.
RobBlash
Hi James,
Is the fix still on track for this week? I have a few folks ready to give me the Ned Stark treatment at this point, so I'll need to go with plan b if the fix wont be in place soon.
Rob
JamesTedrick
Hi Rob,
Yes, the fix is still planned for this week; ideally tomorrow.  Just to verify, have you tested the report on https://survey123qa.arcgis.com ?
HaroldHerrera1
Yes!
RobBlash
Thanks for the update. I haven't had the chance to test in beta, but I will try to find some time tomorrow.
