Error during report generation
2483
06-17-2022 12:21 PM
thoughtsponge1
I tried to generate individual reports for a some records and I get the following error message: "The task failed because all reports failed to run printIndividual. "  Capture.JPG
Does anyone have any insight on how I can fix this?
ZacharySutherby
Hello @thoughtsponge1
Would you be able to pass along your XLSForm for testing on our end? I would suggest reaching out to Esri Technical Support to assist with troubleshooting the behavior.
Thank you,
Zach
BlakeOfstedal
I am having the exact same issue. I've attached my XLSForm.
KevinDonahue3
Was there any resolution on this, I'm having a similar issue and unable to find any documentation on it.
cat206
same here 😞
