Error converting XLSForm
5652
7
04-18-2023 12:15 PM
Lisa_G
Hello,
I am creating a brand new form. I was able to publish it, but the updates did not reflect in the form. The error I receive is 'Error converting XLSForm'  I can't find the reason why this is happening. The last question type I added was a select one type. I checked field names and it is correct. I can't update or refresh the form at all.  I went into AGOL and made sure the select one question field name was added along with the domain. When I try to update the form in Survey123 Connect even with the new field added into AGOL, it will not work. I keep receiving the same error over and over. I sure hope someone can help. Thanks
Vinzafy
Hey Doug,
Values set for bind::esri:fieldType were working just fine, but when a value for the bind::type column was set for select_one/multiple questions, that's where the error came in.
Looked into it a bit more and there was a thread from 2019 indicating that it was a known issue however it doesn't seem to be addressed. Might bring it up again in a thread/open a support case when I have a chance!
DougBrowning
MVP Esteemed Contributor
Things that jump out at me
instance name with special chars concat(${Survey_Date}," || ", ${Lead_ECI_Name}, " || ", ${Survey_Type})
You have the allowupdates thing in 2 places.  Its just the bind::esri:parameters one.
I do not think you need to have the allowAdds one there, at least I have never used it.
Start there and see hopefully that is it.
Lisa_G
Hi Doug,
I have learned so much from you in this forum! For the instance name, it actually works. I have used these special chars in other forms without errors. It makes the inbox records in the form easier to read. Regarding the allowUpdates, I will use the bind::esri:parameters field only. I had used this format before, with the parameters field and did not experience any errors. I have now learned that the bind::type field should NOT be used for type for single and multichoice questions. I suspect using the parameters field for allowUpdates should also NOT be used in conjunction with bind::esri:parameters. Learning things!  Thanks again for your quick response.
Vinzafy
Hey there,
I'm not entirely sure why, but the survey seems to fail when "string" values for "bind::type" in column S are set for select_one/multiple questions.
When the bind::type values for "string" are removed in column S from rows 21-53 for select_one/multiple questions, the survey seems to load properly.
Troubleshooting process was deleting rows to see what caused the issue. I first deleted the repeat and it loaded properly. Then when re-adding the repeat, the survey failed, thus the error was in the repeat.
I then started removing groups within the repeat. I first removed all but one group. The survey failed, so the issue was within the group.
I then removed all but one value within the group which seemed to work (the bind::type was string). Re-introducing the remainder of the group, it failed again. I then deleted all the parameters apart from the field name to see if it would work which it did.
It was then found to be the bind::type values that were causing the issues. Furthermore, it was specifically the bind::types of string that was causing the survey to fail, and only for select_one/multiple questions.
I'm not sure if this is expected behaviour, but it does seem to be a fix for your issue.
EDIT: This seems to be part of a known issue dating back to 2019 based on this thread.
Lisa_G
Hi Vinzafy,
Many thanks for your analysis of the xls sheet for bind field. It was definitely the bind::type values that caused the error. I have removed the bind::types for all single and multi choice questions and was able to update and publish successfully.  Thank you!
DougBrowning
I almost never use the bind type esri except for null.  It should all work based on the question type just fine.
Vinzafy
Hey Doug,
Vinzafy
Glad that's working on your end too! Weird one, but seems to be a known issue dating back to 2019 based on this thread. Might be worth bringing up again when I have the chance!
