Enterprise : repeat with Alias table with space
358
01-13-2023 08:27 AM
RémyGourrat
I create my survey with an enterprise feature layer (not hosted) wich contains some table using alias. some alias use spaces and others things to have beautiful layer name...
so, i can't create repeat question on those tables.
is there a syntax to indicate to survey the table with the layerID in the name question instead of layer name/alias ?
Rémy
Tags (1)
jcarlson
MVP Esteemed Contributor
The alias is what is used to locate the table for your repeats, so "Some Table Name" must be renamed to "Some_Table_Name" in order to function properly in Survey123.
- Josh Carlson
Kendall County GIS
Rémy_Gourrat
workaround when you want beautiful alias table 2 services
Please vote https://community.esri.com/t5/arcgis-survey123-ideas/using-alias-table-with-space-in-repeat-question...
