Enter Paper Surveys
514
5
04-02-2025 01:02 PM
Y2AdminConsultants
I have about 20 paper survey responses from people who did not want to use the computer to take the survey. How do I enter in these survey responses? I've gotten to my data table, but I don't see how to add a new line/record/survey to the data table and put in the answers.
__JackCharde__
Are you referring to the hosted feature layer that's created when you create a Survey123 survey? If so and you own the item, you should be able to edit it in ArcGIS Pro after signing into your portal/AGOL org.
DougBrowning
Best way is to use 123 on Windows and fill out the form.  That way you do not skip the QA checks and all your calcs fire.  If you enter in Pro or a web map no calcs will fire.
__JackCharde__
Great point, Doug!
Y2AdminConsultants
So I tried that, but I can only enter 1 paper survey response. When I go back to try to "take" the survey again and enter another paper response, it tells me "you have already taken this survey".
Y2AdminConsultants
Nevermind, i figured it out! Thanks!
