empty output in instance name
1050
05-19-2020 01:25 AM
מנהל_תקשובמנהל_מערכת
Hi all I get empty output in instance name when using calculated field .
I'm enclosing a sample excel for testing .
does any one know how to fix this ?
Shwu-jingJeng
Currently there is an en enhancement request for issue with instance name using jr:choice-name with instance name:
ENH-000126922 Instance names should honor the labels in Inbox or Sent Surveys box of Survey123 for ArcGIS field app, instead of returning the name of the answers for select one and multiple.
I encourage you to submit an enhancement request via Esri Support. Our Support team will assign an official enhancement number for your records. Similar requests from other customers can then be attached to the same enhancement request, which helps us assess demand for the enhancement and prioritize it accordingly.
