Embedded Survey123 Forms in Dashboard and Experience Builder no longer functioning
1488
03-23-2022 06:50 AM
SamGatter
This morning all of our embedded Survey123 forms in dashboards return an error message 'You do not have permissions to access this resource or perform this operation'
Despite users being shared to the same groups and changing nothing in terms of the dashboard configuration or survey form, they no longer function as they did previously. There was an update to Survey123 yesterday and I presume it's related to this. The surveys which are no longer working were also set to use the version they were published in.
Has anyone else had this issue, or knows of a workaround?
We are using ESRI Enterprise.
AustinWilliams2
Also experiencing this in my dashboard embedded surveys as well.
SamGatter
Hi Austin,
It seems this issue can be solved by repointing the embedded content url to the beta survey123 site - this is the previous thread that ESRI responded to regarding this issue:
https://community.esri.com/t5/arcgis-survey123-questions/embedded-form-in-dashboards-no-longer-openi...
