Editing Sent Surveys in Version 3.1.4.242
795
03-29-2022 06:13 PM
GISAdmin32
Could anyone tell me if version 3.1.4.242 supports the editing and resubmitting of already sent surveys? Our field staff are currently capturing data however one user's tablet was updated with version 3.1.4.242 and no longer has this feature available whereas the previous version did. I have check the settings for the survey and online and it set up to allow for this feature.
Any assistance would very much be appreciated.
IsmaelChivite
Esri Notable Contributor
Hi. After enabling editing in the Sent folder and checking edit permissions in the survey, I see the option to edit sent records:
Checking edit permissions in the survey using the Collaborate tab in the Survey123 website
Enabling edits in the Sent folder in Survey123 Connect:
DougBrowning
MVP Esteemed Contributor
This is posted here also  https://community.esri.com/t5/arcgis-survey123-questions/survey123-edit-a-submission/m-p/1158506#M41...
It seems like 123 is now defaulting this setting to off vs on?  I just found a bunch of forms today I had to repub.  Never had to change the setting before I think.
thanks
GISAdmin32
Thanks Ismael. That worked perfectly!
