Editing existing Data in Repeat doesn't work
270
11-02-2021 04:15 AM
MohammadTawbi
New Contributor II
allowUpdates=true query doesn't work in my survey, I'm using survey123 version 3.12.232. I also have attached the XLS file, please find it below.
thanks,
Mohamed
DougBrowning
MVP Honored Contributor
The syntax I have is
query allowUpdates=true
Hope that does it
DougBrowning
Hope that does it
MohammadTawbi
New Contributor II
I tried both syntax but none of them worked, knowing that the syntax works normally on the other survey123 forms, I tried to save as the same form  and publish it as new feature layer and it works fine and the query returns value in the repeating table.
