Edit existing data in Survey123 Form from Collector using custom url?
4206
11
03-21-2018 08:42 PM
SuddhaGraves
Hi all,
When you launch Survey123 from Collector using the custom url, can you make the form load with existing data vs creating a new record?  When I launch Survey123 using the custom url, it appears to be creating a new record.  However, I am looking to create the record in Collector, but then have the capability to edit the existing record using Survey123.  Any help/suggestions would be appreciated.
Regards,
Suddha Graves
Tags (1)
Tolo__AdamTolo
Also have tried this and been struggling with it.
Thought maybe just needed to change the URL so it is in edit mode but that does not look like it has helped:
Updated to the latest Survey123 connect client as well but that seems to not have helped.
by Anonymous User
Not applicable
@JamesTedrick - Are the above posts a potential workable solution to open Survey123 to an existing record, or has this feature been implemented in another way?
Follow up question: Is there any workaround to view image attachments within the inbox? Perhaps via a url or any other option you've come across?
