Does Survey123 support the XLSForm search() functionality
4608
12
02-09-2017 05:07 PM
Trippetoe
The XLSForm standard supports a 'search()' function which can be used to populate select lists from csv files XLSForm.org .  I have tried re-creating in Survey123 the simple sample from the XLSForm page,  but I haven't been able to get it to work. Instead of the select list being populated with data from the csv file, there is a single select option that is the name of the label field in the csv file.
I can't tell if its something I am doing wrong or if its functionality that Survey123 doesn't support.  If Survey123 does not support that functionality, is there a way that i can use data from csv files to populate select lists?
Thank you.
MitchellProctor
Hi Tom,
XLSForm's search() function isn't yet implemented in Survey123, sorry to say. If you want to use a CSV file to populate a select list, external selects and pulldata() are both supported.
MitchellProctor
Hi Tom,
Trippetoe
Thanks for the info Mitchell.
Is there an example of how i can use pulldata() to populate a select list? I have seen various examples of how to use pulldata() once a value is selected or entered, but i haven't found one yet for populating the select options. Maybe i am not looking in the right place.
I have an external select working in my survey, but i was hoping to use the pulldata() approach if its possible.
MitchellProctor
Unfortunately, Tom, that was me getting a bit confused; you can't use pulldata() to populate a select list. It's best used populating from a select list, you can't populate a select list with one. For your work, the best that can currently be provided is an external select, possibly moving to search() when that's available.
JumaKhudonazarov
so still no search functionality for survey123?
JamesTedrick
Esri Esteemed Contributor
Hi Juma,
Yes, Survey123 currently does not support the search() term.  Can I ask the context in which you need support for it?
JumaKhudonazarov
Hi James,
Thanks. I am trying to use survey123 for patient data collection (field level) and  instead of creating new data for the same patient I can enter for instance UID or name and bring on screen already existing information from first visit.  Also can you please help I am trying to create new survey from  existing XLSF form  when I push publish button  the following message comes. " The survey cannot be published. Only one geometry field is allowed per table, 2 found in your file".
JamesTedrick
Hi Juma,
Based on my understanding, the search() function is not the appropriate function - search() is designed to provide choices for a select_one list based on the value of in a previous question.  What you are wanting (looking up previously collected information) is supported in Survey123 with the pulldata() function.
JumaKhudonazarov
Hi James,
Thanks , helpful  will follow  your  direction.
Best regards,
Juma
BenSmith6
Hi James,
Has the search() function been added, I can't find a shred of information on it
