Is it possible use the absolute value function in survey123? I need to formulate a logic statement based on the weight difference of two things. Example: "If the difference is > 0.3, the test fails." I have not seen any examples online showing absolute value. Any solutions or work arounds you know of would be greatly appreciated.
Thank you!
In the absence of the abs() function, will the above work for you?
You could keep the Calcu question as a 'calculate' and then use that variable in other expressions.
This worked!!! Thank you so much!! Could you explain the language of the calculation in the 3rd row or point me toward a resource that would explain it? I'd like to understand it a bit further. Thank you!!!
Hi Kara,
The statement says:
1) Treat the answer as text and look at the first character of the answer. See if it is a minus sign ( - )
2) If yes, grab everything in the answer except for the minus sign (from character in position 1 - *the second character* - to the end of the answer) and make that the value
3) In not, just give value of the question being looked at
the equivalent using numeric evaluation would be
if(${question} < 0, ${question} * -1, ${question})
Hi Kara.
I used operators and functions as described in this help topic: Formulas—Survey123 for ArcGIS | ArcGIS
Essentially:
There is no single way to solve this, as shown by James above. There may be other ways to solve it too.
Just for future reference, if anyone comes across this...
Under the calculations section they talk about the substr function.
If you want to calculate it in a single Calculation field, you can also do the following:
sqrt(pow(${number1} - ${number2},2))
I squared the number and then took the square root. The result will always be positive.
Hi All
I found a better way to perform the Absolute math function.
pow(pow(${value},2),0.5)
By squaring a value and the finding its square root you are able to calculate the absolute of a value.
