Disable Photo File Name Editing and/or Controls in Survey 123
1682
04-17-2019 09:25 PM
AaronColbran1
When a photo is taken the photo file name field becomes editable if the name field is tapped.  Is it possible to make this read only?
Secondly is it possible to turn OFF image controls like including the FOLDER Icon and Image Orientation Icons? The reason is that all photos need to be captured as Portrait and stay as Portrait, the same as the Tablet orientation when taken photos?
JamesTedrick
Esri Esteemed Contributor
Hi Aaron,
It currently is not possible to prevent editing of the photo's file name or to disable the image manipulation controls.
JamesTedrick
Hi Aaron,
JamesWeir
Hi James, I'm just wondering if preventing editing of the photo's file name is now possible in Survey123?
Thanks!
ChristopherCounsell
MVP Frequent Contributor
Late reply but for anyone else coming across the post, yes this is now possible with the allowRename parameter
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformmedia.htm#ESRI_SECTION1_CCDB2059C7...
