Default values and calculations not working in Repeat when Repeat_Count is defined
771
05-11-2017 06:46 AM
AnnCouch
I am using Survey123 Connect version 2.0.41 and I am unable to get default values or calculations to work in a repeater when I define a repeat_count.  Is anyone else having this issue?
RenatoSalvaleon
Occasional Contributor III
My version is 2.1.9. I am having the same issue too. My repeat_count is dynamic and is based on a spinner integer value of a previous question. All the repeated questions have a default value of 1 - all the questions can only be zero or 1.
JamesTedrick
Esri Esteemed Contributor
Hi Renato,
This is a known limitation with repeats in Survey123 currently.
SuddhaGraves
New Contributor III
Hi James,
I am running Survey123 Connect version 2.8.4 and this issue still appears to be present.  Do you know if there are any plans to correct this?  Or is there another workflow to get around this problem?
Suddha
JamesTedrick
Hi Suddha,
This should be corrected in Survey123 3.0, released yesterday.
