I am using Survey123 Connect version 2.0.41 and I am unable to get default values or calculations to work in a repeater when I define a repeat_count. Is anyone else having this issue?
My version is 2.1.9. I am having the same issue too. My repeat_count is dynamic and is based on a spinner integer value of a previous question. All the repeated questions have a default value of 1 - all the questions can only be zero or 1.
Hi Renato,
This is a known limitation with repeats in Survey123 currently.
Hi James,
I am running Survey123 Connect version 2.8.4 and this issue still appears to be present. Do you know if there are any plans to correct this? Or is there another workflow to get around this problem?
Suddha
Hi Suddha,
This should be corrected in Survey123 3.0, released yesterday.
