Default value of field (appearance = hidden) not populating
450
06-02-2025 10:34 AM
dsinha
Hello, I have a select_one field (called Status) in my form with appearance = hidden. I have also set default = Received.
However, when I submit a record through the form, the Status field remains empty.
Any idea what I might be doing wrong?
Thanks!
Neal_t_k
A couple thoughts:  1) Is there relevancy on that field?  2)how is your list set up for the select one.  Check you are setting your default equal to the Name on your list and not the Label.
Neal_t_k
dsinha
Thanks @Neal_t_k. It was the second solution. I had it set to the label.
DougBrowning
MVP Esteemed Contributor
If it is hidden I would try the calculation column instead.  I have seen stuff like this on read only also.
dsinha
Thanks @DougBrowning. I will keep that in mind.
