Date and time formatting
2209
10-10-2024 01:21 PM
Bio_GIS
Hey all, I am in need of some help with a quick formatting issue. I've got the following printing out in my reports for a datetime field:
"April 18, 2024 11:08AM"
However, I only want to print the time portion. The problem is they're contained all within one variable as such:
${survey_start} and ${end_time}
How would I extract just the time of day?
ChristopherCounsell
MVP Frequent Contributor
If you are using survey123 report templates
${datetime | format:"HH:mm"}
Where datetime is your field value.
https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereporttemplates.htm
DavidSolari
MVP Regular Contributor
Check out the format codes for the format-date function.
ChristopherCounsell
