Data values are valid
9980
13
12-20-2018 08:24 AM
SarahWhitton
I am receiving an error when validating my Survey123 survey in the web app. I receive something that says "Data values are valid Instance name: 2nd Street 1543726800000"
When I try to submit the same survey on the web app on my phone I receive a error code 1000 indicating I have a string that is too long. I'm not sure if these two are related?
I've attached a copy of my survey.
PavlovaVitale
there has not been any solution posted; I am having the same issue. I try to submit a record using connect and it shows up with the data are valid but it won't submit the record. what is the solution?
CourtneyFrost_ForestService
I have the same experience. It's not an error, but a dialog box appears that states "Data values are valid" and it then lists several lines of code that list the survey responses. This appeared suddenly when I was creating a survey in Survey123 Connect. How do I stop this dialog box from appearing?
PavlovaVitale
this issue shows as solved but I read through all the responses here and there is no solution posted. Can you please provide the solution? I am having the same issue and when I submit the record in connect it is not submitted because the message appears.
PegGronemeyer1
Hello @PavlovaVitale
In case you are still wondering... and if I am understanding correctly, the solution is not clear because the message it is not actually an error So that is the solution - there is no error.
You will get that message about data valid... 'see details'... when you are testing the survey in Connect.
You cannot submit data when you are in Connect.  Instead you test then publish the survey in Connect, then open it either in field app or web app, from there you can collect and submit data.
It has been a source of confusion for many of us... e.g.  https://community.esri.com/t5/arcgis-survey123-questions/data-values-are-valid-error-instance-name/m...
Hope that helps.
