Survey 123 Offline Install
688
06-27-2024 03:21 AM
AdamPigg
We have the survey123 website application installed locally following the instructions for offline installation.
Most things work Ok, but when we add a map to a survey we get some issues.  Using developer tools, i can see it fails to load
/esri/identity/IdentityManager.js
From the root of the web server.  it seems like this path is hard coded, and I dont see any instructions on hosting this portion of the javascript API anywhere.
If I manually fix this on our web server by copying and hosting the API, it then fails to load
/dojo/calcite-components/calcite.js
Is there something im missing?  Either we need to host some javascript API locally, or Im missing some config option in survey123 to point it at the correct location for these files.
Any help is appreciated!
xavro
Je me permets de vous répondre afin de savoir si vous avez pu résoudre votre problème d'enquête survey 123 installé localement. J'ai effectivement le même soucis lorsque j'utilise des enquêtes avec geopoint. Erreur de chargement de l'identityManager.js. Avez vous trouvé une solution ?
