Customize this: You have already taken this survey.
881
06-12-2025 04:03 PM
RickeyFight
MVP Alum
I need to customize this message.  "You have already taken this survey. Thanks!"
I am using survey123 connect and I have the setting only one submission is allowed per submitter.
Is there a way to customize it?
Thank you
JamesTedrick
Esri Esteemed Contributor
Hi @RickeyFight ,
Yes, the submission screen can be customized in Survey123 Connect.  Provide a note with the name generated_note_prompt_submitted and place the text you want to display in the label column.  Refer to the documentation section on customizing form elements for more information.
ZenMasterZeke
@JamesTedrick  this doesn't work for me. In fact, it disables groups with a condition in the relevant field so that they don't show at all.
RickeyFight
MVP Alum
@JamesTedrick  I have "generated_note_prompt_submitted" and that is the thank you text after submitting a survey. I am looking for help with the message this setting gives.
I want to change this
SuryaRathanlal
@RickeyFight Were you able to figure out how to update the text that is displayed when only one submission is allowed? I'm trying to do the same update but cannot find the element to be customized.
Appreciate any help on this, thanks!
