Custom URL for Survey123 web form?
6879
21
01-10-2018 08:01 AM
ShaneClarke
Is there a way to open a Survey123 web form and pass field parameters to the web form?
Here is what I want to do: I want to create a hyperlink to open the Survey123 web form and pre-populate fields, including passing the x,y coordinates for the geopoint location. Any suggestions on how to do this?
(Are custom-URL parameters only supported for the Survey123 apps, or are they also supported for the web form?)
Thanks!
ChrisJones4
James,
Lat/Long
From web map
From file geodatabase
JamesTedrick
Esri Esteemed Contributor
Hi Chris,
The pop-up configuration allows you to specify the number of decimal places displayed in a pop-up - the point is being moved because it is rounding to 2 decimal places.  Increasing the number of decimal places shown should address this.
