Creating Tabs
1252
02-24-2023 11:33 AM
MohammadAlattar
Hi everyone,
I've seen a Survey123 with tabs. I am trying to create something like this:
by click on 1 , 2 and 3, each of which, will display another question. How can I do something like this?
Katie_Clark
MVP Regular Contributor
See the section here for "Can I show specific questions based on the answers from other questions?"
https://doc.arcgis.com/en/survey123/faq/faqcreatesurveys.htm#anchor3
That should have what you need, but happy to follow up if you have additional questions.
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
JenniferAcunto
The 'tabs' that you are referring to in your image are repeats. Repeats are the same question or series of questions presented multiple times. You cannot set up 'tabs' for questions outside of a repeat.
Tricks of the Trade: Repeats
- Jen
