Creating a Heat Map
1982
06-04-2022 11:21 PM
ParksBrian
I would like to create a heat map that represents the amount of foot traffic on our hiking trails in the park. We have the tracks of the hiking trails and we can tabulate the number of people accessing the trails.
jahsonroy
To create a map with the heat map layer do the following:
Drag and drop your file (or copy/paste the data)
Click Set Options.
Click "enable heat maps"
(Optional) Change "Heat Map Opacity" or change "Radius"
(Optional) Enable Show Pins & Heat Map"
Generate the map.
Click the heat map button in the upper right of the map.
ParksBrian
Thanks Jahson. Sorry, a point of clarification... what platform are you working in when you follow these steps? ArcGIS Online? Survey123 Connect? ArcGIS Pro?
