CreateReport/SubmitJob Endpoint for Enterprise/Portal (using FME)
428
04-07-2025 05:11 PM
j-bromp
Hi there,
I have posted in the FME community as well however it might be more relevant here.
I am trying to send a POST request to the createReport/submitJob endpoint using an httpCaller in FME to begin generating a survey123 report.
When using an AGOL connection this is the endpoint to use:
https://survey123.arcgis.com/api/featureReport/createReport/submitJob
however I get an invalid token error when using this endpoint with a portal connection. I have tried adding in the portal to that url but then get an unvalid url error.
I am not sure if the request url is supposed to be different when using portal? I know in PowerAutomate we have a custom connector that enables the report generation however the endpoint isn't clearly visible in PA.
Any help would be much appreciated.
Cheers
j-bromp
j-bromp
Have successfully got the above to submit the job. I can also access this endpoint:
https://survey123.arcgis.com/api/featureReport/queryJobs
which provides details about the submitted job but not the actual resultFile,
this endpoint: https://survey123.arcgis.com/api/featureReport/jobs/@Value(jobId) still returns invalid token... any ideas? cheers
j-bromp
Solved
JoshClanton
How were you able to solve these issues? I'm in the same boat
JoshuaClanton
Nevermind I found your FME community post. Thank you!
