create report when basemap and feature class have different projections
1264
09-06-2022 06:42 AM
IrisHadarStltd
hi,
When printing report from survey123 , the "map" part of the report gets printed fine, only when both basemap and Feature class are in the same projection.
For example  when using  feature class ( wkid 2039) and BaseMap (wkid 2857) , it results in map which is not centered on the selected feature class.
Does anyone know if this is the correct behavior or is this a bug .
Attached are two results one with different projections and one with the same projection.
 The Survey was created with Survey123 connect using "feature service" as initial XLSfForm  design.
Thanks in advance,
iris
Richard_Purkis
@IrisHadarStltd It sounds like you are experiencing the same issue as described in another thread:
I looked a BUG-000151785 for it and I just checked the status and it is already been set to "In Product Plan"
I hope this answers your query
ZhifangWang
Thanks @Richard_Purkis @IrisHadarStltd .
We have included a fix for this issue on the Survey123 Beta website https://survey123beta.arcgis.com. It is planned for the coming September Update late this month.
